I've gotten some free time the past couple weeks and I've made some progress.
The engine is all asssembled.
I started on some of the bolt on stuff. Since I'm changing to 12 volts, I'm ditching the generator and putting on an alternator. Most like the GM 1 wire, but I'm using a Mopar alternator. I think that it's a better alternator for one thing and the "1 wire" aspect of the GM alternator is over-rated. I used the original bracket and added some spacers. I welded the two spacers that go between the ears of the alternator to the bracket. That way, if I ever need to switch alternators on the side of the road, I won't have to worry about getting them all in. It makes it a touch more rigid too.
Another update is I'm fitting a PCV system to the engine. Chrysler actually had retro fit systems for these engine going back into the forties! In the early sixties, the PCV became mandatory to control emissions but the upside is the engine oil stays much cleaner and the engine lasts longer. I bought a PCV valve and the cap for the road draft tube from a Dodge Power Wagon and I have to build all the plumbing.
The breather needs to be blocked and a line run to the air cleaner. This will serve as a source of filtered air at low speeds. I've started on the breather, filling the intake hole by soldering a small patch over it. I also had to cover the drain holes in the bottom of the breather.
Paint and decal.
The fill tube got a fitting.
