Opinions greatly appreciated
ashy22
Manchester - UK
the dash has been painted, the vin tag should have a white Chrysler Corporation decal on it.
I've seen worse on the trunk pan. To be as nice as the rest of the car does, it should be replaced, but you could clean and paint it and worry about it another day.
not sure what you mean by centre column....steering column? a 40 year old car won't have the same tight feel as a new car. plain and simple. You get used to it, as long as it isn't excessive.
The vin numbers on the trunk rail are under the trunk weatherstrip, which if it's glued down as it should be, you couldn't see them.
the master cylinder is unpainted when new, so surface rust is normal. What else was rusty?
brakes...rears just my need adjusted, and the front sounds like a caliper piston hanging up. I had one do that so bad I could make a sharp left turn without turning the steering wheel.
what was the price on the car?
If your gut is telling you to keep looking...then listen to it. Keep looking and saving your money, and get the nicest car you can. and not a bad idea to look the GTX over just to compare things.
Thanks for that Basketcase
The orange 383 is 29750 euros firm ($ 32300).
By center column, I meant the center piece where the shift stick is.
that could just be loose mounting screws, or the plastic mounting are of the console could be cracked/broken.
ashy22
Manchester - UK
I am going for the one a few posts back. It looks in great shape.....but no power steering and no power brakes.
http://www.69roadrunner.net/mopar/s...numbers-matching-turn-key-resto-needs-nothing
The import laws have changed over here. Now you only pay import tax of 5% if the car is over 30 years old. Great news.
I am going to get one of those inspection companies to give it the "once over" to make certain everything is as it should be.
A lot cheaper than me flying over to check it out!
Are these people ok for that :- www.carzinspection.com
Cheers
Ashy22
ashy22
Manchester - UK
:party::party::party::party::party::party::party::party::party::party::party::party::party::party::party::party::party:
that's fandamtastic! hope you're well pleased with your new baby. you've picked the best color....now all it needs is some Cragars...:groucho:
ashy22
Manchester - UK
And that's what it now has! Cragar/Unique Supreme 177's :)
15 x 8 rear with 255/60R15 Cooper Cobra Radial GT's
15 x 7 front with 215/70R15 Cooper Cobra Radial GT's (had to import tires from Germany but that's another story)
What do you think?
I'm GREEN with envy. that is a sweet bird.and don't be a stranger!
ashy22
Manchester - UK
looking good! how is it being received across the pond?
very well thanks djais1801.
Looking forward to showing it off at our classic car shows we have over here.
Getting hold of the tyres was the biggest nightmare.
The EU have decided that all tyres need re-certifying and as a result the likes of Cooper Cobra and BF Goodrich don't comply and can't import to Europe.
Unfortunately the UK has to go along with all this bureaucratic nonsense so have to rely on the tyre being found somewhere as "old stock". Running out fast!!!
That's why I had to go 215/70 and not 215/60 on the front.
abodybill
Senior Citizen Member
MI. Farm
Very Nice and beautiful looking Green Runner.:yesnod: :yesnod:
Post up the magazine spread when it comes out.
