No more Road for the Runner!
incredible amount of work, keep the pics coming. very very informative for anyone else contemplating this work
Sixtynine_Bird
France
You do know you can build a road runner with new parts from AMD and buy a deck lid LOL. That has been allot of work!
LOL Absolutely! ^^ that was something I wanting to share in case some of you might need a deck lid, I told myself that it would be a good idea to let you all know that AMD make this part LOL
And for sure it has been allot of work!
Sixtynine_Bird
France
Thank you quickbird, I sure will keep the pics coming, I'll post new pics once the floors are in :)
Thanks too to roadcuda ;)
dmartin
It's gonna look awesome when you finish man I believe that the body work is the most teadist work but it's all worth it in the end when you get behind the wheel and fire it up for the first time nothing like[emoji1308]
Sixtynine_Bird
France
Sorry I didn't take the time to answer.The last two month I have been really busy and still am... But I hope it will look awesome :)
And now I think it is time for me to take some spare time to let you where I am at this time! :)
Sixtynine_Bird
France
Hello guys! Long time no post! Been through a lot of thing since last time I've been posting here!
First the inner fender brace are welded.
We adjusted the taillight lenses with the quarters, wasn't an easy part.
And we did something that we are really proud of because it turned out really nice but I will be waiting on your comments for that, is that between the Dutchman panel and the quarters, you've got that little junction between them like a gutter, anyway, instead of putting some seam sealer in it, we decide to braze (I guess that is the right word) with the oxy ethylene torch in those gaps. Then with this rotating tool on the compressor we sculpted it and we've got a nice finish gutter. And now the water can flow on it without going in the trunk.
Then we went in the car, and start the floors. So we cut out the floors repaired the torsion bar crossmember on the passenger side. We cut out a piece of it then redone it with a piece of metal and welded it back. We also had to redone the reinforcement inside it. After that once the front section floor were out, it was time for us to make the front torque box. So we took a rectangular section and made a "Y" form with it. Then we welded it on the inside of the rocker and the fork of the "Y" on the frame rail. Pics will come it will be easier to understand because it is quite complicate to explain it lol
Once it was done, we manufactured our own subframe connectors as well. We finally welded the whole thing up; for the driver side it was a bit longer because we had to figure it out a pass through for the e-brake cable. The subframe weren't high enough to drill it and make a hole from both side and pass the e-brake cable inside it, but it was lying on the top of the subframe and it was bending the cable. So we had to make a notch in the subframe. For tat we use a handlebar from a bicycle, cut it open in half and welded it on the subframe. So now the cable got a nice channel and it fits pretty well! :)
Once the subframe were in, we began the welding process of the front floor section. Tonight more welding and finally the floors are in!
And after that the car will be coming back from the dead! Because no more repair or body work! Youhou! what a relief! Then just have to make the rear torque box, make some brackets for the rear sway bar, then seam sealed the whole car, and then it could go out of the house for the paint shop! hope current this summer it'll be painted.
We can finally see a sample of the light at the end of that tunnel!
I know this is a tone to read sorry about that.
Thanks for your time and I will add some pic soon!
Thomas
dmartin
Man those rear quarters remind me the the AMD quarters I bought and put in looks great big guy
Sixtynine_Bird
France
Thanks dmartin, wasn't an easy task those rear quarters, a real pain! But now I'm glad we did it, looks better than the previous one, especially when the previous one are mounted in the wrong way...
Sixtynine_Bird
France
here comes the pics! :)
Lets start with the inner fender brace:
Don't have any pics when we adjusted the tailight leses but got one or two of the repairs we did on the stud :
Now lets se what I was talking about on the dutchman panel and the gaps wit the quarters :
Sixtynine_Bird
France
Before welding back the floors lets do the fun part! The "Y" torque box, so first we did a straight bar welded on a plate each side of the extremity. With one plate in a "L" form and a sraight one. The "L" forme one, is welded on the bottom of the frame rail and the straight the inside of the rocker. Once it welded on the car, we took an other piece of a bar of bare metal and welded it on the top of the frame rail and the straight bar to form a "Y" with the torque box, lets see the pics :
Sixtynine_Bird
France
After that here comes the time for the subframe connectors here is the fab process, for the handlebar from the bicycle I forgot to took it in picture when it was finished, so took one after I welded the subframe on the car hope you'll see enough, not an easy shoot! but you'll see the channel that it makes for the e-brake cable :)
Sixtynine_Bird
France
Welding the sub co en the car was a real pain! Wish we could have a rotisserie instead of the jack stands, it would have been easier. But we do with what we have that is the rule!
The "U" form parts with a lot of holes are the parts that goes on the rear frame rails and support the end of the sub co.
Sixtynine_Bird
France
And finally once everything were in, we finally could do the floors, and we finished them last night but didn't take pics of it I will and then I'll post again:
Sixtynine_Bird
France
So that is where we are at this point, lot of work to go yet before paint shop, but it coming along slowly :)
The last modifications are going to be the rear torque box and make something up for the installation of a rear sway bar. Still have to study this part.
dmartin
Man you sure beefing up that unibody I sure hope all is square and right brother
gkent
Ontario
A wise decision is to restore or replace parts as you remove them. There is nothing worse than having a completely finished body sitting in the shop gathering dust while you then restore or wait for replacement parts.
Here's mine - everything that is NOT on the car has already been restored, wrapped and packed away for fast reassembly. I haven't driven this since 1985 - when its done I don't want to spend years putting it back together!
