resq302
Ok, so here's the latest update..... got to spend some more time working on the car today at Dad's house and found out some VERY interesting things. First I removed the headlight buckets and the front wire harness so they could all be cleaned and the bronze paint removed from a previous person who apparently did not mask that well.
Labeled them as I removed them as they are side specific.
Now here is the weird part..... each back side of the headlight bucket has a different colored stripe that appears to have been air brushed on there as there is a soft edge to the paint.
Black and blue
Goldish yellow and red
Individual pics
Front sides of the buckets before I cleaned them.
While these were drying, I decided to start adhering the "skin" from the old trunk gasket back onto the new "core". Its a long, tedious process, but if it works, it will be hard to distinguish from the original thing! (special thanks to my daughter Hailey for taking these pics!) first two are of me cleaning any little residue left over.
Bonding the skin to the core. Again, tedious process as you can only do a small section at a time.
I also found out that the lower blacked out area on the car was repainted as I had been told it was original and not touched. Again, I thank whoever did the paint work on the car for not doing a perfect job as you could tell exactly where the 1/4" pin striping was as there was adhesive residue left on the paint before they painted it leaving a nice ever so slightly raised line that you could see only on an angle with a glare. It seems the stripe was put 3/4" down below the bottom edge of the lower body molding.
Black and blue
Individual pics
