Has anyone have a pic of the corner section of the window showing the window fillers thanksAll good help thanks,do I need to brace.Already have the 1/4 $1600 AUS.(insurance) but still have to purchase remainder.freight is the killer
just buy an extra case or two.May need to make a beer run so you can remember , works for me lol.
I used AMD panels and they are pretty good. One thing I found out too late to fix was the rear quarters radius was a little different then the OEM doors. If you look up from the rear of the car you can see that the door sticks out slightly farther than the quarter. I didn't have the doors on or that could have maybe been fixed. Big Mo.If you’re gonna buy a new whole rear quarter AMD makes a great quality quarter a little pricey but if you want to do it right that’s the way to go, but before you do any cutting on the old quarter take and put car on jack stands level it out and take measurements every two to four inches and right it down so you’ll have something to go by when you put the new one on
es you need to brace the door pillar the length Of door section and cross ways down to the floor panAll good help thanks,do I need to brace.Already have the 1/4 $1600 AUS.(insurance) but still have to purchase remainder.freight is the killer
I have run out of adjustment on the hinges. The door fit's fine but the bottom of one door is curved at the bottom. Start fine a the front rocker the curves out and some gap at the back near the rear quarter. The drive side I am happy with. Fit fine but the body line's are off. You all know that you assemble the car before welding and every thing look's fine but one you are trying to finish the car things just don't line up like they should. So you have to make things work. Had to take some metal out of one hinge hole so it would slide forward to get the gap at the rear quarter rite. This is my last restore job any way's but want it to look good. Russ.Hey Russ don't know if you tried or not but the door can be tweaked in and out by loosening hinges on the door side of the hinge, I had to tweak mine to match up to the new AMD quarters on my 68 it seems like very little but it did help.
Russ, The top and bottom of my door and quarter line up very well, it is in the middle where my problem is. The gap is pretty good also.Have you tried to move the striker in. I am setting my door's now they are AMD. With AMD quarters. Something with the line of the door not matching the quarte. Even if you have the top of the door flush from top of quarter and door. Well it is what it is and not going to be able to do any thing about it. But it all looks better than a rusted out piece of junk. LOL.
Russ, we want our cars to be perfect. I go to mopar in Carlisle, Pa. every year. I look at all models and when they were made they were made to move down the line and out to dealers. If you look at the lines and fit of parts they are not perfect. I did not mention the difference in parts to be critical. It is just the way it is sometimes. My 68 will look very nice when it is done. I will drive it and enjoy it as long as I can. That to me is what this hobby is all about. Big Mo.It is not that noticeable. But I know it and that drive's me crazy. Have worked so hard to make the car perfect. Expected more out of the parts I ordered. I will live with it. No need to call the people that make it or the supply people they tell me your just luck to be able to get the parts. Or some thing that is close to the old one. Moving forward and going to finish the car. Hope it dose not give me a problem.
