So now what about the Roadrunner...
So a lot has been done where do I start? :
- Bench seats :
Front one, has been tore down completely
Sanded the shell
primed it then painted in black
Bought some new foam
rebuild it and reassembled it
Put back the upholstery on it as it was new when we bought it
strengthened the spring on the shell to get a firm sat
Same operation for the rear bench seats
- Transmission :
Disassembled (except for the countershaft end play was good and rotated freely)
removed all the gears from the shaft
Changed the bearing as well as the needle bearing in the input shaft
Every single seal has been changed on the levers and so on
Sanded to bare metal the case and the tail
Epoxy primed it
Painted it with metallic grey then clear coated
Fully reassembled
The shifter mechanism is back on and adjusted properly (I presume lol)
Installed the bellhousing too
- Rear end :
Bought everything new except for the main case and third member.
Every internal parts are new
New tapered Timken bearings
New axle shafts from Moser
New axles, flange, plate, carrier seals
New ring gear and pinion from Richmond : it's a 3.73 ratio
New Eaton truetrac
Assembly of the third member is finally done with a good centered pattern on the ring gear tooth
Back lash is set good too between the tolerance of the service manual
With the third member installed we installed the axle shafts in
Set the end play between the tolerance of the service manual too
Rotates freely
- The car :
Put back the leaf springs on the rear end
installed the rear end on the car
Suspension attached to the rear end
Put back the drums & the old wheels
The old wheels will stay on the car till we finish it completely
Once it's one will put the new rims on it! can't wait to see that
Finally the car is back on the rear wheels after 4 years!! What an emotion to see her on the rear wheels yesterday night!
With that done, we can send her to the paint shop for the final stage, which is the flat black hood stripes and the clear coat on the rest of the car.
Then once the car returns from the paint shop, we can start the reassembly process.
Now lets see some pics :
