1967 'cuda
The air grabber style air cleaner I'd bought was a reproduction with a fiberglass base. There was no mounting bracket to attach the base to the carb or lid to the base. No problem, I made my own bracket out of a bar of mild steel.
The next issue was that the hole for the carb was too big. To overcome that, I masked the top of a Holley off with a combination of tin foil and masking tape. I used the tin foil to act as a filler for the openings in the carb. - It acted as a form-able surface that my tape could stick to. I used 80 grit sandpaper to roughen the gel coat on the base and give me an adherable surface.
After masking the carb I mixed up a couple ounces of resin to build up the area that needed it.
