Hoosier Bird said:Pulled the other head off and I see the same marks on the pistons. Now I must decide what to do. Does anyone think that the #8 pressure issue would be caused by the valves maybe not being totally closed? I have half a notion to put it back together and try to run it with adjustable rockers......what do you guys think/
Per the Comp website that cam is a pretty aggressive hydraulic unit and requires a fairly low rear gear, etc. to properly function. Two questions before I answer yours:
1) Is your set-up (gearing, carburetion, exhaust, etc.) truly complementary of this camshaft? Looks like a basically stock engine with a big hydraulic bumpstick to me...
2) Is this the type of camshaft that you want to run?
Your move.
Ray
