Ranger
I had two. Threw the hand held on away because the tach was off, but still have the bigger box type. That said, I think I fixed it. I pulled and cleaned the grounds on the voltage regulator, ECU and tach. Started it and the tach was dead steady. Just got back from a test drive and still steady as a rock. :banana: Only problem is I am not sure which one it was, but the seeing as the tach was having the problem and it's ground was the more questionable of them all I am suspecting it was the culprit.
Thanks for all the help and suggestions.
Let's hope this ends this thread.
