- Joined
- Sep 8, 2008
- Messages
- 5,059
- Reaction score
- 83
Usually when the ballast resistor goes bad the engine cranks normally but won't start. I've had twp go bad. One on my '74 Duster when it was a few years old, and the other on a '65 Satellite I had after switching it over to electric ignition. I started carrying an extra and haven't needed them. So far at least!!
That's because you were using a double ballast resistor. One side is "hot" when the engine is cranking. That side has less resistance, so more current to the coil. When the engine has started and you let off the key, the other side is now "hot" and there's more resistance so less current to the coil.
With a single ballast resistor, there's full current to the coil, bypassing the ballast resistor when the engine is cranking and then when the engine starts, the ballast resistor is "hot" so less current to the coil.
So... with a single ballast resistor, if the engine starts, but won't run after you let the key off, it's a bad ballast. With a double resistor, it could go either way, depending on which side of the ballast resistor has failed.
