My dashlights and dome light haven't worked since I bought the car about 3 years ago.
In December I installed a new dash wiring harness. Didn't change anything. So this evening after work I started checking it. Found the dome light bulb was blown and replaced it with a new one that will not go off. I checked the fuses and the top one 3amp there is no power. I checked with headlights on and ign switch on. Nothing no power.
So I'm guessing the dash dimmer switch is the root of the problem?
