resq302
Update....... LOTS of progress today! The rear axle is back together and we are so very close to driving it again. The only thing holding us back right now is that we have to bleed the air out of the rear brakes.
After carefully looking at the pics we determined that the yellow word appears to have said "tape" and a long with the blue word on the driver side axle tube "ebrake" I can only assume that they needed tape down the e-brake cables since the pass side is pretty long and gets bolted up to the underside of the body. If that was left dangling during shipment, it could have gotten snagged on something or damaged, hence the need to tape them up. Again, just a theory but that is what we deduced the original pictures to say.
When I was cleaning the black paint off of the third member, I uncovered a yellow crayon marking of what looked to be a heart next to the 2 and a large hand written 4 on top of the third member. These were replicated with the paint crayon which I picked up from Quanta a few years ago.
Yellow "heart" and 9-26 carrier assembly date code. (date code of 9 27 I am awaiting on the rubber stamp to come in for the axle tube final assembly date)
again, you can see how long the pass side e-brake cable is as it has to be attached to the rear axle housing.
shocks installed and bolted up at the top mounting location. Waiting for the suspension to be compressed a little to attach the lower mounting points.
brake lines all installed. Note the new closed cell foam gasket where the wheel cylinder mounts to the backing plate.
e-brake cables installed....
wheels back on, e-brake lines connected to the main cable, shocks mounted to lower location, getting closer!
3 black stripes designate the 3.23 axle ratio with the large u joint and the orange dab denotes the use of Sure-Grip.
