'70 RR firewall holes
WWheeler
Dallas
May have been the last hole that the line worker drilled before the supervisor saw it. I can see the guy's face who goes to install the clutch switch wire and sees the hole in the wrong spot. Who knows, maybe they were used to see modifications and was no big surprise.
I like the pun. Hole some humor.
WWheeler
Dallas
No, it is a very well documented 4 speed. I have the build sheet and all the numbers match (except engine block).
The only thing on my 69 is the revers switch light. Don't know if you guys are looking at the same thing. Being it is a four-speed car.
WWheeler
Dallas
'69s don't have the clutch safety switch like the 70s and therefore wouldn't have this hole. Be lucky you don't have that. It is a PITA and $$ to rebuild.
