I measured the emblems in relation to the studs.
- The distance from the centerline of the stud to the edge of the letters "R" and "D" in road (RoaD), is exactly 3/16". That distance is the same for the "R" in runner (Runner), 3/16".
- The distance from the edge of the last letter "R" in runner (runneR) to the centerline of the stud is 13/16".
[You can also see this with 1968 man's picture of his emblem with studs on page 1. The stud is further away from the end on the last "R" in runner.]
- The gap between the words road and runner is exactly 1/4".
So using that and 1968 man's layout dimensions, you should be able to place your emblems without studs.
You might lay that out on paper first and see if that makes sense.
