I used that very article when recamming my 383. The cam they chose is a little big for a 383 so I went with the Comp XE275HL-10 which has timing events of 231-237 duration (intake-exhaust) with a 110 degree lobe c/l and .525" lift. Its still a little too big for my taste and idle vacuum is at about 10.5". If you have power brakes you may well need a vacuum canister (I installed one in my car).
The other problem with this cam I and others have had is that the idle circuit is rich - so much so that it can really make your eyes water. I have tried many ways to make it stink less but to no avail. At highway speeds my jetting is right on the money. I am running a Holley 750 vac. secondary carb modded to 4 corner idle with 4.5 power valves on both ends.
Gas mileage for me on the highway with 3.55 gears is anywhere from 10-13.5 mpg depending on how fast you want to run, headwind, etc. This past year I drove the car from Orlando to Ocala for the Big Daddy show and on Sat. it got about 13.5 mpg up and back. Sunday it got about 11 mpg with no other difference other than a fair headwind going up. I tried to keep speeds the same; 60-65 mph each day. The power is superb, though, at highways speeds. It feels soooo good and sounds great through the 3" exhaust. It also has a nice, rumpety idle if that is what you are looking for.
I'm toning it down to a milder cam to try and get rid of the idle richness, increase idle vacuum and make the car smoother running. I shouldn't lose too much horsepower - perhaps 20 or so which to me is worth it.
Comp has some milder sticks that would be worth looking at if you aren't going to run headers, a better than stock intake and carb and ported heads.
