Big John said:Buy a cheapie 1" travel indicator with a magnetic base. You'll need this for other tasks down the line anyway.
:yesnod: :yesnod: :yesnod:
69hemibeep said:Hyper pistons are tough as nails, they require different clearances so the choice will need to be made after the machinist checks the block for size. There are allot of wives tales out there about hyper pistons. I use them and a friend has been using them in a twin turbo rig and breaks everything but the pistons. Any personal experience guys?
Anyway, search for Harold Brookshire on here and I'm sure it will pop up - if you're interested.Big John said:Speaking of crankshaft thrust surfaces, I had a problem with one back in the 70's that drove me crazy.
I built an engine for the race car and the first time out, the car just fell on it's face. It kept going slower and it was obvious there was something wrong internally. I pulled the engine apart and the thrust surface of the crank was smoked along with the bearing torn apart. I talked to a bunch of people and the opinion was it was just a bad crank. Tried it again with the same results.
Changed the block and crank for the next try. Same result! By now, I saw the trans was smoked. Changed the crank and the torque convertor and had the trans rebuilt by someone else... another crank hit the scrap pile.
I called Turbo Action, the maker of the convertors and my valve body...... he said "geez, it could be a line pressure problem... but... that would be the valve body"
The valve body was the piece that was common to everything. I pulled the trans apart and the thrust washer in there was toast but everything else was good. I put a different valve body in the trans and, of course, a new crankshaft, and that solved the problem.
That cost me a ton of $$, a lot of frustration and most of the racing season that year.
now he's added a larger injection system and upping the compression to make the cam work. we as a group had an intervention with him to put a smaller cam in because he had no intentions of doing all this, but he's dead set to prove the cam is not to big :loco: :lmao: :lmao:
ACME A12 said:[quote="Big John":11pmi656]Speaking of crankshaft thrust surfaces, I had a problem with one back in the 70's that drove me crazy.
[/quote:11pmi656]69hemibeep said:I'm a fan of Comp and Lunati also, remember its better to go a little small on a cam than a little to big. A friend of mine bought a 502 chevy crate mtr slipped in a larger cam to make it betternow he's added a larger injection system and upping the compression to make the cam work. we as a group had an intervention with him to put a smaller cam in because he had no intentions of doing all this, but he's dead set to prove the cam is not to big :loco: :lmao: :lmao:
ACME A12 said:69hemibeep said:I'm a fan of Comp and Lunati also, remember its better to go a little small on a cam than a little to big. A friend of mine bought a 502 chevy crate mtr slipped in a larger cam to make it betternow he's added a larger injection system and upping the compression to make the cam work. we as a group had an intervention with him to put a smaller cam in because he had no intentions of doing all this, but he's dead set to prove the cam is not to big :loco: :lmao: :lmao:
Harry - DO NOT READ MY RESPONSE TO THIS POST!!!![]()
Bob, I'm with your friend; there's no such thing as too much cam. That's an old wives tale... Now there are such things as not enough compression, not enough carburetion/injection, valves and ports that are too small, a convertor that is too tight, and not enough gear, but there is no such thing as too much cam!!! :lmao: :lmao: :lmao:
Harry - we now return you to your regular scheduled programming...
How about too much cam for the intended use of the equipment :toetap:ACME A12 said:69hemibeep said:I'm a fan of Comp and Lunati also, remember its better to go a little small on a cam than a little to big. A friend of mine bought a 502 chevy crate mtr slipped in a larger cam to make it betternow he's added a larger injection system and upping the compression to make the cam work. we as a group had an intervention with him to put a smaller cam in because he had no intentions of doing all this, but he's dead set to prove the cam is not to big :loco: :lmao: :lmao:
69hemibeep said:How about too much cam for the intended use of the equipment :toetap:ACME A12 said:69hemibeep said:I'm a fan of Comp and Lunati also, remember its better to go a little small on a cam than a little to big. A friend of mine bought a 502 chevy crate mtr slipped in a larger cam to make it betternow he's added a larger injection system and upping the compression to make the cam work. we as a group had an intervention with him to put a smaller cam in because he had no intentions of doing all this, but he's dead set to prove the cam is not to big :loco: :lmao: :lmao:
69hemibeep said:Hypereutectic aluminum has a lower coefficient of thermal expansion, which allows engine designers to specify much tighter tolerances.
moparchris said:I have yet to have any QC issues with MP but Comp on the other hand. Well, I just dont want to get into it more than I have personally seen more than a dozen Comp cams ground wrong or even bent! I am a firm believer that Comp has BIG issues with their QC. There customer service when something does go wrong is THE WORST!!!! Buyer beware. :cents:
:yesnod:
