6PKRTSE
I have always used whatever 10w30 is on sale. No need for anything more fancy. However, I do run Brad Penn racing 10W30 or Valvoline VR1 in my race car for the Hemi.
Me too!I use the 20/50 my selfView attachment 27495
In these cases I would suggest a block heater that you can plugin to 110 ac. Most diesel motor's have them. Sure you could find a place to put one. Or maybe one of those heated blanket's.![]()
I know a lot of people here will attest to the diesel oil but it is not designed for a gasoline engine. Even the zinc content has been reduced drastically as the EPA has mandated that diesel engines use catalytic converters and zinc has a negative effect on the converters. Also, the diesel engines do not rpm like a gas engine and especially a stout gas engine. I wouldn't use it.Rotella T5 10W30 with a bottle of ZDDP Plus.
Yes it does, if that is the oil you like add some zddp to it.Does a 1971 383 have flat tappet cams? I just bought my car doing first oil change now and wen with Car Quest High Mileage 10W 40 and a K & N oil filter. I think it's more important how often you change your oil than what brand you use...
Russ, I think there is a huge disparity between then and now. I replaced a camshaft on a '78 Ford 302 due to wiped cam lobes. The car was run on 10W40 and had oil changed every 3000 miles (late '70's to early '80's motor oil). There was no mud, it was more like pudding. I had to scrape that shit off the front of the motor in the timing chain area. Conversely, I pulled the oil pan on a '97 Pontiac 3800 with well over 100K on it (run on 10W30), and to my surprise, what I found in the pan was no different than a trans pan. Just a light film. I guess my point is, todays oils are SO much better than oils of yesteryear, that you just can't compare then and now.Have removed many oil pan's in my life and the junk that is built up in them would surprise you. It looks like mud.
