So after getting all the wiring in. Found out that the under dash harness did not have the wire for my revers light under dash. I tried several wires that where under the dash. They where not the one for the light. Traced back to Z on the bulk head connector and found out their was no wire on the harness for that light. Got my old harness and their it was marked with duct tape revers light. Removed it from the bulk head connector and cleaned the connector well. Put it into the bulk head connector and hooked it up and every thing works well. Also put my horn in the car new and a new relay. But horn did not work so traced and checked the horn it worked when applying power to it. So the new horn did work and checked the relay by jumping the ground side and it worked. So that put me back to the horn pad on the steering wheel. Boy was thinking hope I can get the bird button out with out braking it. It came out fine. Pulled the pad off and got to the horn mech pulled it off and cleaned the contact area really good. Tested it and horn work's. Put all back together and now it is working fine. So if you have a problem with electrical issues take your time and you will figure it out. Bad connection's or contact is always the problem it seems.
