Where can I have a new fender tag made
4spd69RR
Winter Springs, FL.
I'm in the same boat with a tag that is more or less so eat up with rust it is unreadable. The bad part is I don't have the original build sheet. Galan will not make a new plate unless you supply him with a copy of the buidl shheet and picture of the plate.
nicanor
I can read from the back side but the same as the front. Its either there or eroded away.
Thanks,
Barry
moparstuart
Thanks,
Barry
If you send him ( back east data tags ) a picture of your tag and a properly graphed out new tag, I'm sure he will have a harder time saying no . Just dont add any codes that should be there and make sure you get some of the lynch road guys around here to help lay you out a tag and maybe graph is on lined paper and scan and email to him .
