We have lift-off
6R9Runner
Atlanta, GA
Thanks for all the thumbs up.
Has anyone replaced the 2-speed wiper motor with one of the "flush-mount" type required for the oval air cleaner? Do I need a new switch too? Ok now I'll check the schematics and try to answer my own question...
Should we interpret this to mean that you scored the "A12 Four-Barrel" air cleaner???
Yes there is a different switch. All of the wiring should be in place from the factory for either switch. In addition to the switch and motor you will also need a different linkage cam.
Passion4mopars has eveything you need and their website says the following:
"If you are doing a 2 to 3 speed conversion on a 68-70 B Body application, you will have to replace the wiper motor crank with part #2822273, 3 speed bushing part #2580200, and a 3 speed switch part #2864014. The rest of the linkage, wiring etc remains the same."
Here's their website:
http://passion4mopars-moparbodystyles.blogspot.com/
Hope this helps.
Ray
John69RR
Houston, Texas
Kim, Passion 4 Mopars, rebuilt my 3 speed and did a good job. Very knowledgeable. She is a member here but have not seen her post in awhile. The hood looks great.
6R9Runner
Atlanta, GA
Yes there is a different switch. All of the wiring should be in place from the factory for either switch. In addition to the switch and motor you will also need a different linkage cam...
Ray
Thanks for the excellent information- it looks like I need to sort out the wiper motor situation first.
G
Guest
Guest
Awwww I'm around, just quiet lately :grouphug:
