If those are steel freeze plugs you might want to change them out to brass.
69hemibeep said:If those are steel freeze plugs you might want to change them out to brass.
wannarunner said:Anybody good with CSI'ing Trannies? The pad on the passenger side has (as far as I can tell) the numbers 30102570. there is the number 34104 on the drivers side. On the bell housing there is the numbers 433-8, also on the bell housing is the letters/numbers +33-8 with an X above it. There are 5 of the 12 boxes filled with the dots.
PICS
John69RR said:wannarunner said:Anybody good with CSI'ing Trannies? The pad on the passenger side has (as far as I can tell) the numbers 30102570. there is the number 34104 on the drivers side. On the bell housing there is the numbers 433-8, also on the bell housing is the letters/numbers +33-8 with an X above it. There are 5 of the 12 boxes filled with the dots.
PICS
In Galens white book, automatics are stamped on the drivers side pan rail. The numbers consist of Assembly plant, Part Number, 10,000 day calander date and a build sequence number. He also states that in 69 some engines & transmissions were stamped with the 13 digit VIN on the LH top front of the transmission. Normally though only the 8 digit numiber is found. THe 34104 number does not show up in the book. 34106** or 34107** identify it as a 1970 transmission. 1969 transmission part numbers start with 28920**.
