zupanj
Changed title to reflect current diagnosis.
This not at all what I was expecting. My Runner wouldn't start last weekend and it was clearly fuel as the carbs were bone dry. I kept taking stuff off and really couldn't see a problem. I have an electric pump on the back in-line with the mechanical pump so I thought I should be golden. I recently put a vapor separator on to make it look more factory and it seems the electric pump was just pushing fuel back into the return line but couldn't push it to the carbs on it's own. So thinking about it I wondered if the brass tip on the fuel pump pushrod could have worn down and so the mechanical pump was no longer working. I ordered a new pushrod from Mancini that came this afternoon. After taking the pump off and removing the pushrod, I found what you see in the pics. The brass end looks good but the pump end is mushroomed like crazy. Also it looks like the fuel pump arm is worn down significantly but it is hard for me to tell since I don't have a new one to compare. I don't know what to think about this nor how to fix as that side is clearly not getting oil. Any thoughts from you guys? Also it looks to my eye though I haven't measured yet that the new pushrod has a slightly smaller diameter. Does this matter? I may post this elsewhere to see if anyone has any ideas.
