I forgot to mention that the scored area on the sure grip (scalloping)is old damage from 10 years ago when my old 3:23 pinion was loose and rubbed against the housing.
These are Richmond gears now(4:10).
2 days before taking the car to the strip we replaced the yoke because of a stripped u-joint strap hole.I was still running a "crush" sleeve and I may have crushed it a little more when replacing the yoke. I know the drag resistance felt a little bit tighter when I was finished.
This probably did not help matters.
On a lighter note,I'm glad I had a rev limiter,AND I'm glad I don't use an automatic transmission,or I would be replacing it as well.(no offense to those too lazy to row the gears)![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
John
John
