Did you buy a kit and do you think this is something that should be rebuilt? When I looked at mine the rubber seal is not torn but is pretty hard. I just looked on Parts Mix at a kit PT# 1001028 with red seal. Is that what you used? Your bud Big Mo.New pin- shoes- and the top rubber seal with holding bracket. Put new grease in it. Around the end where the bearing is the guy on U tube put a strip of peal and stick foam for a bottom seal. Just to keep dirt and such out of the bearing.
