Hoosier Bird
Looks great, have you driven it yet?
John I hope this helps, keep in mind my brake lines come off the fender side of the master. The speedo cable also has a clip that pushes onto the frame rail just about where it goes out of the picture!John69RR said:Bob, do you have apicture of the drivers side engine bay where the brackets for the wiring, speedometer cable and brake lines go? I took a picture of mine but I'm not sure the brackets are in correctly. Thanks.
Not yet, but I plan on firing it for break in this week :cheers:Hoosier Bird said:Looks great, have you driven it yet?
No the carbs are still getting a make over, I have another Carter I'm going to set up and block the other 4bbl off. If my throttle cable will fit I will also get it in for wheel alignment. The plate was a funny story, I went in and wanted a vanity plate 69hemi or something like that, but they will no longer issue 69 anything because it has other meanings. So the guy at dmv said how many cubic inches is it, my plates are in the 400s and he dug out this one. My wife said it means "rapid eye movement" my friend likes "remanufactured" I told the guy at the muffler shop I would get the mufflers and resonators from Accurate since all he has is Walker and glass packs, and he said if you going that far get it all and if I have trouble bring it in. He said Accurate was better as original looking than he could do.ACME A12 said:Looks great, Bob!![]()
So you opted to install the Accurate Exhaust Products' system yourself instead of having your local guy fab everything up? What drove your decision? Just curious...
If you're planning the break-in already does that mean you got your carbs back too?
"426 REM"...426 and your initials...???
Sorry so many questions...
ACME
69hemibeep said:The plate was a funny story, I went in and wanted a vanity plate 69hemi or something like that, but they will no longer issue 69 anything because it has other meanings. So the guy at dmv said how many cubic inches is it, my plates are in the 400s and he dug out this one. My wife said it means "rapid eye movement" my friend likes "remanufactured".
Join the gas guage dilema club !!!69hemibeep said:OH CRAP :toetap: :toetap: :toetap: I put 10 gallons in my tank and it shows almost a 1/4 tank :toetap: :toetap: :toetap: The first 5 got it to empty :toetap: :toetap: :toetap:
I hope you will have your video, audio unit ready and working when you do this. Right!69hemibeep said:Not yet, but I plan on firing it for break in this week :cheers:Hoosier Bird said:Looks great, have you driven it yet?
IF soneone sold an accuratly calibrated one they could make a mint , I heard frank babalson did so i bought one , gauge just goes up to 3/4 full when tank is full .Ken King said:Join the gas guage dilema club !!!69hemibeep said:OH CRAP :toetap: :toetap: :toetap: I put 10 gallons in my tank and it shows almost a 1/4 tank :toetap: :toetap: :toetap: The first 5 got it to empty :toetap: :toetap: :toetap:
:brickwall: :huh: :leave:![]()
69hemibeep said:It has to be an arm adjustment because I ohm tested it and its good :crazy:
I forgot to pat you on the back, yes that's goodACME A12 said:69hemibeep said:It has to be an arm adjustment because I ohm tested it and its good :crazy:
:yesnod:
Did you like my interpretation of "REM"?![]()
69hemibeep said:I forgot to pat you on the back, yes that's goodACME A12 said:69hemibeep said:It has to be an arm adjustment because I ohm tested it and its good :crazy:
:yesnod:
:jester:![]()
[/quote]
[/quote]
