Rear window lower stainless steel moulding
vso737
California
The rear window stainless steel molding on my '69 Roadrunner has a screw on both ends to keep the stainless strip mounted. Some genius drilled a hole on each corner of the molding to make sure the strip stays mounted.
My question is two part. 1) Can the holes be filled and then polished to make it look new?
2) Is it better to purchase an 'after market' lower stainless piece and will it be as good as the original???
Funny how the small simple things end up causing most of the headaches........................
LG,
Mike
Not the first time that has been done but I'm not familiar with welding stainless or how well aftermarket trim fits. Good luck.
Rapid Transit
Just A Traveler In Time
I have some limited knowledge.
My guess is that unless it is exactly the same kind of stainless it might be a different color.
I also think TIG is the only option for it.
And the person doing the welding should be very good.
Warpage might also be a minor issue.
However, on a positive note, it's a small thing and won't show much.
torredcuda
New Hampshire
I have the same issue on my passenger side. I think a good tig welder could weld up the hole and then it could be ground and polished. I have heard the reproduction mouldings don`t fit well so I am hunting for a good used one.
Trim is thin and rough to weld up. Do not think you would be happy with the results. Better off to find new trim. Maybe AMD has it. Know it will not be quite as the same sometimes. But could be happy with it.
WWheeler
Dallas
New trim is an iffy fit. When restoring my bird, I matched the area around the glass to fit the trim.
ykf7b0
Tennessee
I'm sure a past owner was having an issue with the stainless not lying down properly in the corners. My 69 drivers' side rear window stainless doesn't lay down in the bottom corner really well at all and I've tried to remedy it but it appears to me the only way to get it down really well is with a sheet metal screw. Does anyone know the secret of getting those pieces to lay flat in the corners?
Jack R
Gilbert, Arizona
Stainless can be welded but special weld process that I don’t remember exactly. If there is an aerospace weld shop around you they could do that as that’s a primary weld type for them.
