Pulling my A833 trans.
Can I pull the trans. if taking the shifter loose and disconnect the shift linkage loose. Hope I can sneak the trans. out. Need to do a seal replacement on the front shaft. I have a console and really don't want to pull it if I don't have too. Thanks for any input. Russ.
HD539
Pacific Northwest
It seems like you should be able to. With that said however I pulled my console last time I had my transmission out.
You would have to disconnect the exhaust to tip the engine far enough to clear the the cross member. Take the shifter off.
MoparDan
Stuarts Draft Virginia.
Russ it seems like everyone has covered it. But I would remove the shifter handle, remove the transmission crossmember and unbolt the transmission. Support the bell housing. That's it
