Hoosier Bird
I just had to buy those jack stands cause they match my runner.......
Probably a little overkill for the frame but those 12 ton ones go up to 32".
That was all on the inside?Hoosier Bird said:It was all on the inside of the frame, and that was before I sent it to the Blast Shop. I got another gallon out after that. :loco:
Hoosier Bird said:I just had to buy those jack stands cause they match my runner.......Probably a little overkill for the frame but those 12 ton ones go up to 32".
That sounds like a good idea, Where'd you get that from? :devil:Hoosier Bird said:This should work if I decide to put those sand rail tires on and hit the dunes..... :lmao:
It looks like you're going to have a real strong frame there, Gary!Hoosier Bird said:Got everything welded up solid. Time to get out the grinder, flap wheel and other finishing goodies......![]()
