Power disks brakes, brake pedal goes to floor
rose heiden
Rosebud
florida
Thanks Russ. I see u live in Fl too. We live in thw panhandle. Do u ever go to the mecum auctions in Kissimmee?
rose heiden
Rosebud
florida
Back again to say we are having the same problem with the brake system (pedal is very mushy). I partially went thru a yellow light with the brake pedal to the floor, going 20 mph. Can't go back to mechanic shop that fixed it. They say they don't know what else to do. So I would like to get a referral to a classic auto mechanic business that is not to far from where I live (Fort Walton Beach FL). Does anyone have a referral you can give me? thanks
Sorry to here that rose. Has any one checked the power booster for leak's. Wish I could help you out with some one to work on the car. Where do your local car guy's hang out. They might could steer you to a good one. :(
rose heiden
Rosebud
florida
Thanks Russ. The local mechanic we took it to adjusted the rod between booster and pedal and rod between booster and master cylinder. They didn't mention any leaks from the booster, but we will check it out. So I did a post on Classic Cars of Navarre for a referral to a classic auto mechanic. Got a couple replies back. We got to one of their shows late and are trying to catch some other shows. Wanted to check this forum too for more referrals.
Hope you can get it fixed soon. These brakes are basic. Was it working ok after you got it back from the other shop.
V.R.D
florida
DeBroux Automotive Inc
Website
Directions
Save
Call
4.779 Google reviews
Auto repair shop in the Ferry Pass, Florida
Address: 9009 N Davis Hwy, Pensacola, FL 32514
Hours:
Closed ⋅ Opens 7:30AM
Phone: (850) 477-3317
this is a shop i used for my fleet in that area and great owner tell them Vance said to call.
rose heiden
Rosebud
florida
VRD , thanks for the referral.
Russ, after work at shop it worked and slowly got mushy again. Going to look at replacing master cylinder and check booster for internal leaks. Thanks a bunch.
Have you noticed if you have a leaking wheel cylinder. Or maybe a leak some where in the system. Just thing's to check on you own. Sorry to here the luck. These system's are simple as they get. Don't figure why this keep happing to you. Russ.
V.R.D
florida
russ might be on to something . when bleeding each wheel cylinder and you get air from 1 and not any other that wheel cylinder is sucking air it is bad and needs replacing.
Have the E brake set right so if the pedal fail's at least you have them to back you up. I did drive home with just using the E brake one time till I could get the brake fixed. Just saying. Man hope you get it figured out so you can get back on the road.
rose heiden
Rosebud
florida
That's funny, got a laugh out of that. My older brother was just here for a visit. He's 73 and had a new 1970 runner in fall of 1969. So he drove mine with me. I told him brakes were bad so he was careful. He punched it a few times and made the tires squawk . I'll have to try that myself. He said he drove his in first gear 105 mph in a quarter mile before he put in second gear. Got up to 145 mph. That was a new runner 383 automatic. Don't want to try that in an almost 52 year old runner. He's got a lot of stories. Vietnam vet too. Lives in spring hill fl.
So Rose have you ever replaced the the power booster or rebuilt it with a new diaphragm. Have replaced many of these over the year's in different car's. They get a pin hole in them from age and will leak. Check all connection's for leaks. I know this is frustrating to say the least. It will drive you up the wall trying to find the problem. Gees girl wish we lived closer so could help. Having problem's with my door window right now trying to get thing's to work well. Catch ya latter.
