roadrunnerh said:the original ones make me smile when I'm cranking.
They always make me wonder if I gonna have to roll the battery charger over and give it a 200 amp boost just to get it spinning fast enough to actually crank...
I have friends coming over today from out of town - which means Bambi will get driven some today. Having sat for the past week or so there will be no gas in the fuel bowl and a marathon mopar starter grinding session will be in play; I'm almost resigned to pulling that PITA LOH off and nailing her with some starting fluid just to expedite the process... Conversely June Bug (my 340 powered '74 Duster) has sat for the past month and will also get fired off today. The difference being that she has a Powermaster mini starter and will pump gas up the carb in no time and will bust off before Bambi's reciprocating assembly has even made one revolution... You guys knock yourselves out with the flat map of the world...I'm using a globe...
