Bingo :basketcase:
Big John said:A31PKG said:To further hi-jack this thread: I'm good with the avatar & signature.... How does one get a "ranking"?
You just gotta say something that my version of insanity finds funny.
A31PKG said:Big John said:A31PKG said:To further hi-jack this thread: I'm good with the avatar & signature.... How does one get a "ranking"?
I'll work on that..... :huh:![]()
. Now change your ranking :acme: :leave:69hemibeep said:Ok John (OZ). I know I was right about the speaker hole in the rear deck. Now change your ranking :acme: :leave:
ACME A12 said:looks to me that you're already good-to-go, Craig...
Try sod, it works.A31PKG said:ACME A12 said:looks to me that you're already good-to-go, Craig...
Awesome! :banana:
Now if I can only figure out how to get grass to grow in my friggin' yard.........
moparchris said:Try sod, it works.A31PKG said:ACME A12 said:looks to me that you're already good-to-go, Craig...
Awesome! :banana:
abodybill said:Paint it GREEN and be done with it!![]()
Jim S. said:I stock piled some of the old 15-40 Rotella before the tree huggers pulled all the zinc out of it. When I run out of that, guess I'll use 20-50 Valvoline with zddp additive. Amsoil makes "Z-Rod" in 10-30 and 20-50 with high zinc but, it is pricey. Curious to see what the other guys are using also......
The shelf-life on properly stored, unopened motor oil is 4 years, After that time, the oil should be properly disposed of at an oil recycle location.
Doug Hund
Shell Lubricants
doug.hund@shell.com
