A31PKG
The 383-440 value should be between 3 1/2 to 5 psi. The 426 should be 7-8 1/2 psi. I do not recall the exact specs on my Carter elec pump, but the pressure was well within the correct range. I want to say 5 psi+/-. I'm certain that the needle & seat could withstand a higher pressure, but I went with factory specs. The mounting location was more a matter of convenience than anything. There was already a hole in the rear shock crossmember (I believe its from the factory) and it was close to the outlet pipe of the fuel tank/sending unit, so I used it.
