No power everything dead
jhj747
Illinois
I have a 69 roadrunner driving car died out no power. Got home I checked the fusible link wire was broke. I ordered a new one . So I took a wire with a 50 amp in line fuse connected it just to see and still no power at all. Every thing dead . I screw driver the starter relay car did turn over. What can it be . I did check all the connections on bulk head look good .
I'm a new be under the dash
I just purchased the car the person who had the car put in a volt meter it looks good i look under the dash at the factory alternator gauge there is a silver prong but now wires i see.
Check your connections at the amp gauge
Your awesome i seen the wires under the dash i snuggled up the nuts bingo power! Now should I leave it or put the wires together with a nut and bolt and tape up. If I do will it effect the gauges on dash. Thank you again
I bolted mine together, wrapped and insulated the connection
Thank you again. I just picked this car up in Tennessee and going through it. The speedometer is at 100 and bounces the previous owner put a new speedometer cable on it didn't change. He put a new dash in same style as the original but white. He said it did work but started acting up. You have any ideas?
I was hoping to find someone i could take the car to and have them do it. Electric stuff I'm list on.
