Map light
Any one have pic's of the dash map light. I have the hole but nothing their. Is it just a lens or is it more. Would like to put back what ever their is suppose to be their. Thanks. Russ.
Plybeep68
Acceleratii Incredibus
dmartin
Be sure to put LED bulbs in all your light fixtures to keep them cool and not burn through the plastic
not all had map lights some had block off
All had the hole in the dash, but only had the map light if you got the (A01) light package. Without your data plate to know how your car was built, you could put in a light or block it off, what ever floats your boat.
Yes with out knowing what the car had dose make it hard. I got the blank off plate for now off E bay. Appreciate the help. Can always put it in latter. Have been buying switches and all trying to get the dash set in. It was a thought of putting that light. Good picture Plybeep68. Saved it to my pictures. Good idea dmartin on the led blub's. Yes droptop I know that with out knowing what was on the car makes it rough to say the least. Any one following my rebuild knows this car was striped inside of a lot of stuff. Just would be neat to have that map light I thought.
It was storming hard when trying to post a thank you. Satellite signal was not coming threw very well. Pic. Was a help.
