moparstuart
i have not gotten my plane ticket in mail yet pops69hemibeep said:Four weeks left, you can make it![]()
moparstuart said:i have not gotten my plane ticket in mail yet pops69hemibeep said:Four weeks left, you can make it![]()
ok great i dont mind a 2 hour joy ride :jester:ACME A12 said:moparstuart said:i have not gotten my plane ticket in mail yet pops69hemibeep said:Four weeks left, you can make it![]()
Everything is electronic these days, Stu-Rat. Just go to the airport that Thursday morning...I'm sure dear old Dad has a ticket waiting for you...![]()
John69RR said:Just got a call from the machine shop. The crank is LIGHT!!!! That means Mallory Metal at $39.00 per piece. I need 2 -3 pieces. The crank has a bobweight of 2300 grams. My stock rods and KB215 pistons equal 2400 grams. Now it will be at least Monday before I get it.
i dont get why your crank is too light....you told them what you have and the crank should be a drop in...right....or you should"ve bought a better quality crank and you wouldnt have this problem....am i correct??John69RR said:Just got a call from the machine shop. The crank is LIGHT!!!! That means Mallory Metal at $39.00 per piece. I need 2 -3 pieces. The crank has a bobweight of 2300 grams. My stock rods and KB215 pistons equal 2400 grams. Now it will be at least Monday before I get it.
YES JUST ADD PLUGS...drilled and poured in or welded on but why wasnt it balanced before it gets to the consumer??69hemibeep said:Probably just add plugs to the counter weights![]()
John69RR said:I did talk to 440 Source before buying the crank. The crank is balanced with a bobweight of 2300 grams. Here is a "cut & paste" from their website.
All versions come pre-balanced at a specific bobweight (listed with the model,) setup for internal balance. The bobweight we use is usually somewhat heavier than the final bobweight of the finished rotating assembly. The reason for this is to ensure you won't need to add any metal to the crank during balancing. For normal applications, all you will need to do is lighten the counterweights down to the desired amount when the final balance job is done. Adding heavy (mallory) metal to a crank is a very expensive and time consuming process. Removing metal is simply a matter of drilling holes in the counterweights, which is a normal part of any balance job. This makes balancing inexpensive, easy, and able to be done by any local shop.
Shown here is our 3.75" stroke crankshaft for low deck "B" (383/400) engines. This crank is popular for 451 stroker setups in 400 blocks. Crank includes the following specs: Stroke: 3.750" / Block Type: B / Main Journal Diameter: 2.625" / Rod Journal Diameter: 2.375" / Rod Journal Width: 2.050" / Pre-Balanced Bobweight: 2300 Grams / Counterweight Diameter: 7.120" / Flange Bolts: 6 x 7/16" In Stock
When the machinist called I couldn't believe it. I thought I would be good to go. Apparently the stock Mopar crank is considerably heavier since all it needed was balancing, no Mallory Metal. I figured with the KB Hypereurtectic pistons that the weight would be light enough. Would an Eagle or Ohio crank be any different? Who knows. I understand they are all made in China and QC is not the greatest. I trust the machine shop to do it right.
:drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :leg: :leg: :leg:John69RR said:$500.00 later I picked up the crank and block. The block was line honed, the crank had to have one piece of Mallory metal, balanced, new cam bearings and the mains are now .001" undersize. Now it's time to put it back together. Spent time with the family in San Antonio on Spring Break. Has anyone ever been on a Segway? Those are a trip. Took me about 15 minutes to realize that you won't fall over. Also spent a day in Bryan at a Beerfest. Now that was fun. There were over 200 beers. Hopefully I can start on it Monday. Heres a picture from Beerfest.
