Looking for rear gear opinions.
I have to agree with basketcase on this one, I don't think changing out the gears will give much more than 2 to 3 miles per gallon more. To me that is not enough difference for the time and effort to change out the gears. Now if you had 3:73, 3:91, or what I have in mine right know 4:56 I probably would change them.
dobie said:
Someday i swear ill drive mine there, 3.91 gears and all!
I've done it 3 times! Round trip for me is about 340 miles. I fill up before I go, and can usually make it to about Dillsburg before I fill again. I keep my speed at 55 most of the way and just enjoy the drive!
I think that the difference in ratios (2:73 vs. 3:23) will not net you as much MPG as keeping your speed low. Crank up the air pressure in your tires too... at least 35 psi.
:thumbsup:
Good to know, although my round trip is almost double that at about 630 miles.
Of course.... gas in PA is a LOT cheaper then gas in CT!!!!
That's one thing I'm counting on!! :yesnod: And I have also been keeping the tire pressure around 32 or so. Thanks for all the comments guys, it gives me a lot to consider.
