zupanj said:
Chris,
I have a hydraulic roller cam in my hemi with a bronze distributor gear and a bronze tipped fuel pump rod. How often should I look at those for wear and is the wear obvious? I have seen some pictures of distributor gears in the past that were pretty subtle in terms of wear. I have been worried about this a little but I have put so few miles on the engine that I haven't really looked at anything yet. This engine does not turn high rpm, it is no longer making power at 5400 rpm.
I don't mean to hijack this thread but your post made me wonder.
I like to look at them when I am changing my oil, which is usually once or twice a year. What a pain in the a$$. There is no need to worry about that ever again with the modern gears. The fuel pump pushrod is a different story. Your probably the only guy in the US who uses a mechanical pump on a billet roller.
![LOL :lol: :lol:](/mopar/styles/default/xenforo/smilies/smiley-face-laughing.gif)
:acme:
george68hemirr said:
chris.....i see what you are saying......at the end of the year i will be pulling the motor for a rebuild.....starting to smoke.....too much gas washing the walls with those 1050s......i just want to do a band-aide fix to get her back running for now
I would really consider a freshen up right now. When a lifter, or any part, goes bad it sends fragments throughout the motor. This tears up bearing in a few seconds. 6 years ago I had a flat tappet go bad and I shaved about .100" off the lifter in about 10 minutes time. I was so disgusted with the situation, I mothballed the car for 6 years. A few months ago I tore the engine down and was just going to band aid the cam and clean up the engine. Well, the crank had some serious scoring and the bearings were so badly scored that I doubt it would have made it another 100 miles without getting a rod knock. Mark my words, YOU DO NOT WANT TO DESTROY THAT EXPENSIVE HEMI TO SAVE A FEW BUCKS. The end result will be a broken car this summer anyways. Please give this some serious consideration buddy. I'd feel really bad if you did a temporary fix only to window your Hemi block.
