moparstuart
:toetap: :toetap: :toetap: old cam still looks great even where my fuel pump rod got eaten , i will reuse this one inmy 440 for my 69 charger 500
moparstuart said:my old cam was great but not for a six pac it just made it fuel to much and had no vacuum , this new one should draw 20 vac .69hemibeep said:I guess I should have read the last of page 3, I thought you had a problem with the cam :leave:
this will make the six pac be way more adjustable. we are pretty sure the extra fuel combiles with the hi torq started hydro lock my number 2 and twisted the rod .
l
droptop said:You need to make sure you know what caused the hyd lock. Was there any signs of a coolant leak? If not, the only other thing that could have caused it is a carb flooded and filled the cylinder with gas. Check them out or it will happen again, no matter what kind of rod you use. :yesnod:
wrong cam was the problem , carbs are brand new back from holley , the cam would not allow any adjustment at all on the center carb , mr six pac told us why . so the new cam should fix the problem , but we will know for sure when we goto re set up the carbs .ACME A12 said:droptop said:You need to make sure you know what caused the hyd lock. Was there any signs of a coolant leak? If not, the only other thing that could have caused it is a carb flooded and filled the cylinder with gas. Check them out or it will happen again, no matter what kind of rod you use. :yesnod:
X2 - I was thinking the same thing, Harold. Fix the problem, Stuart - not just the symptom.
