Interieur lights stay illuminated
oscar holland
Something strange when i close the door
The light goes off but when i keep my hand over the lights (center consol and roof) the are still on verry little but the are
excuse my typo
you have a bleed from another circuit, bad ground etc somewhere. will drain battery maybe so yep, need to find it
It sound's like a peck and hunt type of thing. Wonder if it is bleeding through a switch some where. Sorry to say get one of those voltage testers with the light in it. I don't know if the dimmer switch on the dash could bleed over or not. Maybe some thing bleeding back on the ground.
RKNRLR
Sydney, Australia
excuse my typo
Had the same problem in my old fairlane. Didnt have the patience to go through electrical gremlins, so I just pulled the globes.IMG_71463872230978.jpeg
oscar holland
Wire from switch on passanger side contacted earth a little put some isolation arround it now it’s fine
But what a hasle
To find
You bet it can drive a man crazy to locate something like that. But better than paying someone else's and they muck it up for you. Russ.
Ernie
Try rotating dash dimmer do lights flicker go out?
Ernie
Try rotating dimmer lights flicker or go out?
oscar holland
New electric problem
Blinkers where working fine flash lights as well
Now as soon as inhit the hazzard
Light fuse pops normal blinkers don’t work at all anyone a idea where to look?
Ernie
Ok what are working on?
Do you have a DVOM?
“. Test light?
“. Wiring diagram?
What would you say is knowledge of electronic?
Suspect ground fault
oscar holland
Ok what i did nonwas disconect the switch at the steering wheel for directions emergency flasher works fine (front) think there is a problem in the switch
oscar holland
Yes i have a wiring diagram
Knowledge of electric systems with me is
Open for improvement
Is ground also the problem with poping fuses?
lthnx
Ernie
Then turn signal switch is suspect and likely source of ground fault. Wire in column may have cracked or chafed
oscar holland
Russ you are wright! Drilled the wires to the rear lighting and yes that makes the sparkle......
Oscar you did what. How did that happen buddy. You hit the wire's while drilling a hole is that rite. Man always something hey. Glad you found the problem. Hope it is a quick fix.
