I started putting insulation on floor today. Got done up about half to front started at rear. I used the foam with foil like on both sides that Lowe's sells by the roll. Hope it helps keep some heat out of car.
My daughter needs to show me how to get the pics from my phone to computer then I can post pics,LOL. Your friend Big MoDid you look a the X matt Eastwood sell's. It was pretty cheap considering. What other product's go for. Any thing is better than nothing. Their was one kind on U tube and they said to stay away from it. It dose not stick after a while. Post some pic's. I had some posted in body interior and trim of the X matt.
Russ, did you tape the joints? I didn't know if that needed done.View attachment 30682Here is pic's of what I used and it covered quite a bit for 75 dollar's.
No Russ it is the type I need to spray adhesive down first. Hope it works. Your bud Big Mo.I used 3M A/C silver tape on the joint's. Figured it would be a good idea. Dose the insulation you got have a peal and stick. It was slim line that I saw on U tube they had a problem with it. The guy was taking all of it off. Just to say. Don't know how good the stuff is that I bought but had a good rating on it when looking around. Don't work to hard their is plenty left to do.
Yes I told my buddy that he better watch or he would get a buzz,lol Big Mo.Ok Big Mo. Watch those fumes from that glue. It will give you a head ache. Keep us up on the car's progress. Russ.
I finally finished the insulation. Need to tape joints. With water damage working on the bird is a bit slow. Big Mo.View attachment 30682Here is pic's of what I used and it covered quite a bit for 75 dollar's.
