I've been doing a nuts and bolt restoration for three years now. Of course I have a life to fill the gaps.
My fuel gauge has never worked. First thing I did was get a new fuel sending unit, nothing. Had other problems and didn't work on this but from time to time. I have spent about fourteen hours (beer breaks) with separate car friends for the last three days just on this problem
I believe the gauge works because I attach a wire from the battery ground to the connector behind the driver kick panel where the schematic says to the fuel gauge and the gauge slowly goes to full. (help me if this is wrong). I checked continuity form wire that attached to the fuel sending unit ot it's other end behind the kick panel and that's good. I checked the new sending unit and the ohms change when i move the float that attaches to the rheostat and that's working.
When I hook it all up,,,nothing!
69 Hemi stated that the ohms from the fuel gauge and the sending unit have to match. Huh?
Russ, I did clean the back of the gauge cluster when It was out. (don't remember how)
Even though I believe the sending unit (along with the original that I threw away) work, I ordered a new one that has not arrived but didn't see anything about ohms when I ordered it. (Maybe didn't look close enough)
What are the ohms for these supposed to be? How do I check the ohms on the fuel gauge? As far as I can tell the ohms on the sending unit change depending where the float is.
This problem has been a issue since I got this car but after this week I am lost.
Help!
