Thank you guy's for the info. Time to take a die grinder to this one and move on to getting this car done.
So now with the motor in. Started to install the A833 trans. It would not go all the way in. Found out the hole in the crank is not deep enough. The trans. input shaft is too long and will have to cut it off some so it will fit. Any ideas would be appreciated. Look's like about a half inch too long.
Yes Brewers is very good. Call them they are happy to advise you. Very knowledgeable people.Hey Russ, I found this page on Brewers website very helpful when trying to order parts for my 4 speed.
http://www.brewersperformance.com/orderinfo.php
Your shift pattern is more a function of the shifter then the transmission. The A833 is drilled and tapped for front mounted and rear mounted shifter. The front mount is always used for B Bodies. The shifter should be a Hurst Competition Plus.Ok you guy's know that I have the 383 car with the roadrunner transmission. Working on getting it in and cleaned up the Hurst shifter I bought. So It look's like I would have to push away from me and up for first straight down for second. Then two me up for third then down to forth. All the way from me and up for revers. Dose this sound right. The trans mission numbers are PP833 2814 0004 Up above that on the stamp plate is 9138417. The only thing I could find to reference was on U Tube but that transmission had the shifter at the end of the tail shaft and mine is up front. Any ideas would be appreciated. Russ.
