Now that you mention it, I almost think the ballast resistor had been changed when the kit was added.
Yes, my ballast resistor came with the electronic ignition kit so this was replaced.
After it runs and warms up a bit, does it not start, or does it not crank? Those are totally different issues to solve. Let us all know! It does look as though your wiring on the starter relay is correct. Double check the yellow wire. It is not melted is it?
The wiring is fine. The yellow wire is not melted. Right now the motor starts up just fine on a cold start (the engine fires and runs under its own power). Push the gas pedal once, turn the key and it fires right up. Runs great. As it warms up, the coil gets VERY hot very quick. Turn off the car. Turn the key, and it just won't fire up. The motor cranks fine (the engine turns under the power of the starter motor). It just won't fire up. It acts as if someone turned on a kill switch. So after letting it cool down or icing down the coil with a towel and ice cubes, the motors fires up just fine. For some reason, that coil is overheating...getting so hot that it will burn you when touched.
I noticed you have an engine ground strap. (the 8-10 gauge wire that runs from the fire wall to the rear of the right cyl. head) Make sure the connection to the firewall is good.
Thanks for the info and where to find the new voltage regulator! I will be replacing my voltage regulator as well as the ground wire that connects between the firewall and the engine block. Right now the ground wire has a good connection on the backside of the motor and firewall.
Also, when you were making your voltage mesurement with the voltmeter, it appears you were in current measurement mode. Your voltmeter should be in VDC position to measure the voltage at the coil. Think of voltage as the amount of water above the dam. Think of current as the amount of water flowing over the dam. And resistance, (IE the loads of the coil, ignition, lights, horn,etc.) as the size of the dam. Try your measurement again. Ask more if still confused.
This makes perfect sense. Thanks I will try to measure it again with the proper setting.
