Any one got pic's of the rear window area. Need to see the Trim and how it set's on the glass. Got mine down pretty good but a little high in the corner's at bottom. When test fitting with clip's taped in the end's want to roll up towards the top. Any suggestion's would be most appreciated. Or if any one has encountered this problem. The fear is that with all the stacked up metal back their and having to fill in to make it smooth could be the problem. Well hope some of you guy's have run into this your self.
