A high volume pump will pump a stock pan dry. A high volume pump move more oil per revolution where as a high pressure pump merely has the pressure relief valve shimmed to relieve at a higher pressure. I highly recommend a stock volume pump for a stock pan.railrider said:generaljmwlee said:I know i dont have a high volume pump. because I was told I had a stock pan and could suck it dry at high rpms. High pressure I might have?
Actually I think its the High Pressure that will suck your pan dry. I have ran many High Volume Pumps with stock pans without issue at High RPM. I always ran a gauge to watch it. I thought High pressure pumps were for Circle Track Racing or something. Might be worth checking into. I was told by a pretty reputable engine builder you need 10 pounds of pressure per 1000 RPM. Anything more is a waste he says.
