Sounds like a nice reliable build! Headers?
WELL THATS GREAT....SOUNDS LIKE IT GOING TO BE BAD ASS AND I BET YOU CANT WAIT TO HEAR IT SCREAM.....WHAT COMPRESSION YOU RUNNING??generaljmwlee said:I cheated had the machine shop do the bottom end and redo the heads,all i did was put it together. block had been cooked,honed, new freeze plugs, and cam bearings. crank was ground ,was all installed with clevite bearings,and new rings(just a stock bottom end)the heads were cooked ,resurfaced 10thou, newguides and valves, harden seats . all that for under a grand but it took 2 months to get it back
now I put a comp extreme cam one step up from stock,with their lifters and double roller timing chain.stock rocker set up stock replacement edelbrock alum intanke and a 1406 edelbrock carb. mp electronic dist conversion. and a mellings oil pump. dont think I left any thing out. wanted to keep it close to stock and hopefully I will get ok mpg and beable to run no more than mid grade gas. what do you guys think?
motor must have been redone right before me because cylinders were round and not even a ridge from the pistons
i would say your going to run 93 octane....not the mid gas eithergeneraljmwlee said:10-1 was stock correct? 10 thou off heads dont know what if any that would do for compression
generaljmwlee said:used clear powdercoat on the intake just to help keep it clean,and factory gray hi-temp powder coat on the exhaust,even got the exhaust mounted.quick question is I use stainless steel bolts to mount the intake do i want to use antiseize or lock tite? I was thinking antiseize
ACME A12 said:What a great picture... Hopefully one of the MoPar rags will do an article on the car and will use some of the pics you've taken along the way to tell the story. I'm over all of the "Mr. Smith purchased the car in terrrible condition, dropped it off at XYZ Restoration Shop, wrote some really big-A$$ checks, sent a transporter to pick it up two years later, and now it sits in his game room between the Ferrari Dino and his '70 LS6 Chevelle SS Convertible with air conditioning (one of none - but he doesn't know that and as long as he keeps writing checks no one is going to tell him...) serving as an exquisitely restored drink holder for his imported Chardonnay" stories...
mcmopar said:I put the engine in place and then install the intake afterward just to be on the safe side - but that's just me. 650+ lbs is a lot of weight to put on 4 small manfold bolts.
