Fuel pump rod replacement
Did you push the pump rod up when you replaced the fuel pump?
If the cam lobe was shot, the pump rod would be messed up too... They also don't fail from sitting.. They wear out with use. You established that the rod was good and was moving up and down. It also did pump gas for you once.
Sorry to be harsh, but judging from your other posts, I think you are just shotgunning parts at this car without figuring out the problems. All that does is empty your wallet and frustrate you.
dmartin
I did not mean that the lobe failed because of sitting I meant it maybe time to replace it
72RR440
SW Florida
Just a heads up for the next guy replacing a fuel pump. Prime the pump by pouring some gas down the fuel line of the out side of the pump.
