dirtybird#7
- Joined
- Apr 18, 2020
- Messages
- 28
- Reaction score
- 24
Hi all, trying to sort out an issue on my 70 RR where fuel sprays out of my carb air vents after some hard driving and once the engine is up to operating temps and essentially chokes out the engine. It will only fire back up once it’s had a chance to cool down. I do have an external and in line electric Malory fuel pump with no return line and my fuel regulator is keeping between 4-6 psi. I think it may be fuel pressure build up in the tank as I have a non vent cap. Would it be as simple as replacing the cap with a vented one or drilling a small hole in my current cap? I’m running a ProFom 750 4 barrel double pumper carb (same as a holly 4150). Here’s a pic of the carb with circles around where the fuel is spraying out. I think these are simply air vent tubes for the float bowls located directly behind the metering block, my guess is the pressure is unseating the needles allowing the gas to escape.
