Fuel gauge connection?
Now that your cluster is done and you know the gauge works and you said it works from the kick panel but not from the tank you have norrowed it down to the wire from the kick panel to the tank. Either look for a break or run a new one.
Russ Hood
TN
Good thread. Mine is only going up to quarter of a tank.
I put a new one in my car. Did not like the way it sat and had to bend it to the front of the tank. It is a new tank and different than the original one. Also, by raising up the rear of the car it changed things. You may not have to do what I did. Good luck you have had your share of problem.
