Just say with the rake on the car was not reading right. The sending unit goes straight towards the filler neck. The incline in the tank will not give the right reading. Have to get it to lay down in the front of the tank where the fuel is more ample. If you go to Harbor freight and get a fuel line bender can bend it like you want it. With tank empty looked through the filler neck hole with the neck removed will give you a good Idea of what your looking for. Had to do the same thing on my 73 charger after putting air shocks on the car. I have an after-market tank. Or maybe these after-market sending units are not bent like the original ones. Wish you luck it is a challenge to get these things to work like we want.
